degas cap leaks
4x4grey88
Nascar Fan #88
Kalifornia
I recently purchase my F250 with a 6.0L. I conducted all the usual maintenance procedures and replaced the degas bottle (and cap) because I found a crack in it. I had thought that my leaking problem would have stopped with that replacement.
Lately I have been noticing the liquid level dropping in the degas and finding the indication that the coolant is coming out the cap (onto the brake booster, etc). I do not believe that there is a leak in my EGR cooler because I am not seeing 'white smoke' nor water in my oil. The engine and tranny temp indicators read normal. I can see the flow from the EGR cooler and it looks normal to me.
I don't over fill and my warranty is up, so the dealer is hopefully the last resort.
Any suggestions on what to look at?? I looked at some of the other threads but they really do not answer the question.
I don't want to wait for any major problems.
melmount
greensboro nc
flash boiling, I think thats what its called. Could cause it. I am sure lots here will chime in.
fordoor
SDD Member
N. Calif.
A pressure test of the coolant system would be a start. The degaus cap should also hold 16psi . I believe when they do this they elevate the rear of truck and remove the EGR valve to check for cooler leak and prevent hydraulic cylinder lock?* Headgasket and or EGR cooler leak can be the typical culprit for loosing coolant. A minor HG leak doesn't always blow a lot of white smoke. In regards to the boiling of coolant; here is a description of how the coolant performs within the cylinder jackets, etc. Scroll down towards the bottom for this. http://www.dieselsite.com/index.asp?PageAction=VIEWPROD&ProdID=42
raaustinf16
Argyle/Tx
Look for white smoke out of your tailpipe. I experienced the same thing. Replaced the Degas cause it was cracked. Later that week the level went down again. About that time I started noticing white smoke out the tailpipe on occasion. Turned out to be a bad EGR cooler housing. replaced it 8K miles ago about 6 months. cost me $2300 at the dealer. Guess what. It is happening again and it is out of warranty. this seems to be a common thing with the 6.0 that Ford ignores till someone lays a class action lawsuit on them. alot of the folks on here have installed a EGR cooler delete module. That may be my next step.
I lost alot coolant on a trip and the truck did not show any signs of a head problem so cleaned the EGR and put new o-rings in and have not had the problem any more. I now have a po299 code so I now get to pull the turbo and clean it next. Have to love your PSD to put up with this stuff.
ckamp52
ckamp52
italy,tx and stephenville
yeah mine was doing the same thing but i could see water coming from the egr cooler so i jst kept filling her up for a weeek or wo before i could fix it ....did studs and the egr and cooler delete now hopefully no more problems$1900 bux well spent
4x4grey88
Nascar Fan #88
Kalifornia
I replaced the EGR and did not see any liquid inside. I don't see white smoke. I will have to check out the EGR cooler though to make sure.
This seems to be a common thing with the 6.0 that Ford ignores till someone lays a class action lawsuit on them.
I agree with you on this one.
HeavyAssault
King William, VA
Make sure your new degas bottle has the new level sticker or is the newer bottle with the lowered MAX/MIN indicators. FORD at some point lowered the MAX/MIN line where the coolant level needs to be when checked. Your bottle may be overfilled. If you post some pics I can tell you what you got, even the cap has been redesigned.
4x4grey88
Nascar Fan #88
Kalifornia
I did get the lower level indicator bottle. My first (cracked) one showed a higher MAX/MIN level. I will try to get a picture of it in the near future.
As I indicated in past posting after replacing the degas bottle and cap I have been getting high pressure over-flow, brown color antifreeze, but the temp gauge reads normal. I don't see any liquid in the EGR area (while replacing the EGR), nor do I get white smoke from the exhaust.
Ford records indicate that the water pump was replaced at 25K but no reason was give as to why.
I am not thinking that I am having any head gasket issues but I would like to know why the degas bottle is blowing out.
