F-450 HOTSHOT
- Joined
- Sep 12, 2006
- Messages
- 26
- Reaction score
- 0
I have a 1999 ford F-450 (7.3). And the other day I was dirving down the road and noticed that the truck would not go over 65mph. And then it was going slower and slower with the pedal all the way down. Pulled over to check the filter and stuff and noticed that i was leaking fuel from the bowl drain valve. I got the leak to stop got back in the truck and it ran fine. After about 5-10 miles it started to do the same thing again. So i pulled over to check if it was leaking and it was not got back in the truck and it took off ran fine again. Unitil another 5-10 miles it started to do it all over again. And kept on doing that till i got to my destination. Changed the valve in back of the bowl and the fuel pump still does it. What else could cause a problem like this.
