Trouble light reset?
Guy JR
Stratford Ontario
Can I reset the trouble light in my truck myself? The truck has been to the shop 3 times for the emissions light and every time they tell me there was a turbo under pressure fault and there is nothing wrong with the truck. It runs fine and I'm sick of paying to have the shop reset the light. Any suggestions?
fordoor
SDD Member
N. Calif.
A less expensive way to go is ScanGaugeII - Scan Tool + Digital Gauges + Trip Computers* SCANGAUGE II.* Read and clear codes(turn off your own CEL), monitors MANY engine parameters(gauges),is also a trip computer and more. $169.95 online!* If you're serious/technical/mechanically inclined and have the money, then the Autoenginuity is the more professional way to go. My scangauge II fits perfectly in the little cubby hole in dash. I drilled a hole in the back, velcroed to the top of cubby and it looks almost stock like, very clean.
focus1
IL.
Turbo boost codes
If that has truck has factory pcm software I mean no chip the vanes in your vvt are sticking and you need a turbo teardown and clean.
Guy JR
Stratford Ontario
Whats involved in a turbo tear down and clean? Is this something you need the Ford dealer for? Where can I get a assembly drawing of the turbo? Much thanks to all the help from you guys.
Guy JR
Stratford Ontario
Thanks Fordoor. You would think the Ford mechanic would have recomended this. I should be able to handle this job.
Skram
