sorry I bought My 6.0h
FordDieselDog
edsf460 said:
what did you replace it with?
Same thing: F350 SD 4x4 CC DRW 6.0L 6spd. I pulled 14,000 lbs up a 9% grade in 105 degree weather, with no overheating or temperature issues.
edsf460
Dallas PA
edsf460 said:
Thanks for the info i just got it back yesterday I'm probably going to indiana fri and see how it pulls loaded
I got the truck back and went to Indiana thursday. I picked up 2 mpg I went from 14.9 to 17.0 at 71mph and pulling I went from 6.5 to 7.9 mpg. although the truck seems to have a little more power I still has trouble maintaining 63mph in 5th gear then when I started hittin the hills in PA she started heating up again only this time nothing was coming out of the coolant tank. The outside temp was 66 degrees and I didn't pull no 9 degree grades. This time when I got home i called a lawyer instead of the Ford dealer
mjstef
Big Sky Country.........
Helena Montana
Mine pulls fine on the interstate but is a gutless wonder till about 20 mph.............. :cussing:
TacoCat
