smoked tail lights on white truck??
Big K
SDD.com Hacker/Admin
Dallas, Texas
Can you elaborate more on the Load Eq's??
Load EQ's = Load Equalizer
What it does it puts a LOAD on the circuit and heats up like a regular bulb, so that the circuit seems like the regular bulb is still there.
You will need the 6 OHM Load EQ on each side for the rears ;)
Big K
Dallas, Texas
Also, can I get some more info on Thermo Flasher vs. an Electronic flasher?
Thermo Flasher heats up and this is how it knows how fast to flash.
Electric is all electric and uses the rate of flash that is built into it. :sweet
Big K
Dallas, Texas
This isn't the BEST diagram but it works ;)
I can look up the wire colors if you dont' know them.
Nope, on the OBS trucks, it doesn't have the LIGHT OUT Feature like other cars/trucks have in the Thermo FLasher.
I even ran the Thermo Flasher with the LED's and they flashed fine and before installing the Load EQ's, I did put the Electronic Flasher in and it didn't change a thing ;)
I'm still not get'n it.
My 91 Didn't have the Light Out Feature. My 2K Doesn't have it Either.
When I switched to LEDs with the Thermo flasher.. The T-sigs flashed Real fast, almost a flicker. I simply changed out the Flasher, to an Electronic type and EVERYTHING works just fine. No Eq's.
Am I missing something ??
Big K
Dallas, Texas
Yeap, it is just that the OBS trucks are wired differently ;)
I have to pull the wiring diagram and maybe yall can figure it out :sweet
But I do know, without them, it just doesn't work and the Electronic Flasher made no difference at all :dunno
Big K
Dallas, Texas
OMG i hate splicing connectors, do yourself a favor and wire it in permanetly.
Yea, I know, but I used them for the time being, they are back behind the lights and is out of any type of weather, but I will change them for sure when I check them after a few months! :sweet
FlorWhitfe
