or should I get these?
3157-xLX3 Luxeon LED bulb
Super Bright 3 Watt LED 12VDC replacement bulb
16mm Single Intensity Wedge Base - Brightest LED Tail Light bulb on the market BRIGHTER THAN MOST STOCK TAIL LAMP BULBS! - DO NOT USE IN GM DRL's
Super Wide 130 Degree Viewing Angle
Those are the ones I went with. I like'm.
But again.. The style and shape of the light housing will have a lot to do with the reflection and projection of the LED light beam.
Big K has a handle on OBS truck lights. I'd follow his lead.
