smoked tail lights on white truck??
Big K
SDD.com Hacker/Admin
Dallas, Texas
No matter what model years.... there is a very good information page, about 12v LEDs at SUPER BRIGHT LEDS home
Yeap, But they sell nothing like these! :D
:sly
SMT Tower (US Patent Pending)
30 High Powered Wide Angle SMT LEDS
3157 replaces 3057 3155 3357 3457 4157
These Bulbs have Advanced Surface Mount Technology LEDS + Advanced Patented Circuitry
25 high powered SMT side facing LEDS - 5 high powered SMT forward facing LEDS
Only 20mm diameter x 52mm overall - fits all stock housings
Tried a pair of those. Wernt BRIGHT enough behind the smoked lens (for me). Lost a couple of the side facing LEDs too. New technology ?
Maker and Style of Tail Light assembly comes back into play ?
To each his own:sly
Big K
Dallas, Texas
Joe,
Maybe, but these are brighter than the STOCK ones and fill out the entire assembly.
Also, they have these.
Eagle-Eye Tower (US Patent Pending)
11 Super-Power Wide Angle High Flux LEDS
These Bulbs have Advanced Patent Pending Control Circuitry Found in no Other LED Bulbs
These are the most advanced and brightest led automotive bulb assemblies ever produced.
More powerful, consistent color and more stable than any other automotive leds made.
1 Super High Powered 3 Watt Wide Angle Flux Forward Facing Led
10 Side Facing Wide Angle High Powered LEDS
Fits thru the standard 1" diameter hole.
Crumm,
I am guessing you used regular Red 3157 Bulbs and not LED bulbs ;)
I used led's but not like the ones in your picture. They had like 10 led's right on the end but none on the side.
Looked like this:
I don't think they were shining on the reflector, just shining out the back which was not enough.
Joe,
I'm Good with the Luxeon's, wife followed me the other night'n said I need a Dimmer Switch on mt Tail lights;)
I'm good for now.;tu
I went to LEDs, all 'round, on our 5r also, but have 2, switched from the Cab, marker lights to go yet. I might try some of Tower type again there.
Big K
Dallas, Texas
Looked like this:
Yeap, those are JUNK :sorry
I am very picky about my lighting, if it was not as bright or brighter than stock, I would never ran them ;)
GilroyRacing
Nanjemoy,Md/Mansfield,Pa
I was looking into using those.
3157-x25 LED bulb
25-LED 12VDC replacement bulb
16mm Dual Intensity wedge base for Tail/Brake applications (SRCK/SACK compatible)- DO NOT USE IN GM DRL's
Unique design has 19 LEDs aiming out the end and 6 radially mounted LEDs aiming 90 degrees from the base for better lens fill
Select LED Color
in red of course.
Is that one ok or no?
GilroyRacing
or should I get these?
3157-xLX3 Luxeon LED bulb
Super Bright 3 Watt LED 12VDC replacement bulb
16mm Single Intensity Wedge Base - Brightest LED Tail Light bulb on the market BRIGHTER THAN MOST STOCK TAIL LAMP BULBS! - DO NOT USE IN GM DRL's
Super Wide 130 Degree Viewing Angle
Slickbr
