whatabudro
Launched
- Joined
- Jun 12, 2005
- Messages
- 0
- Reaction score
- 0
Are you the winning bidder yet Mike?
No, there is a difference between the OBS pumps and the SD pumps, the SD pumps work on an OBS truck, but in that application there are bleed down issues.powerboatr said:are you saying that 02 7.3 had a bleed down issue of the hpop resivior?
Only the 94-95 models WILL have that problem if the 94-95 guys put a SD HPOP in their trucks. They will have to do one the mods Radarman mentioned.powerboatr said:are you saying that 02 7.3 had a bleed down issue of the hpop resivior?
Thanks95_stroker said:No, there is a difference between the OBS pumps and the SD pumps, the SD pumps work on an OBS truck, but in that application there are bleed down issues.
We'll try to go slower for ya next time.![]()
Jim,THE_ALASKAN said:Only the 94-95 models WILL have that problem if the 94-95 guys put a SD HPOP in their trucks. They will have to do one the mods Radarman mentioned.
JIM
I got it for almost half what a new pump costs. If this is going to be a cluster of a mess, I might just re-sell it and do more research next time. I was un aware of the incompatiblity issues. I figured the SD HPOP was the cats jammers for a cheap way out to better high pressure oil.whatabudro said:Mike did you get a good enough deal to offset your new costs?-popcorn
95_stroker said:Jim,
Will the SD pump guts slide into the OBS pump housing?
