bearracecars
Hi guys.
I have a 03 excursion with a 6.0 in it and 107000 miles. The motor is all stock except for a cat back i think. Its been running good since 07 when i got it, and the oasis was very good, not much had been done to it. I did replace the hpop shortly after i got it, but it was on its way out when i got it.
Starting a few months ago, in the morning when i start it up it has a miss, if I rev it up a little, it feels like a dead hole. No smoke, exhaust looks normal. When it warms up it goes away and runs just like normal. Or if i start it up and dont warm it up fully and shut it off and let it sit for a little bit and what ever heat is there starts to saturate, it will also run fine.
I have been getting the codes for cylinder 1,2,3,4 injector control circuit low. (ie.p0264) My fuel mileage has also gone down.
Is this possibly my FICM going out?
Thank you
Bear
Thank you
Bear
