Plowing Snow
05duramax073
Diesel Nut
Union Grove WI
At work i use a 2006 Ford F-550 Powerstroke flatbed to plow snow. Normally have no complaints about the truck, has good power, hauls a ton, and can go down the interstate at 75 no problem loaded down. Today was the first day we used this truck to push snow. Nothing but a pain in the a**. I had two units of 3/4 inch T&G OSB on for weight and did nothing but spin. No traction what so ever. Was just wondering if anyone else has had this same problem or if it was just a fluke thing.
I've done some plowing in a Dually F350 with a Reading body installed and tore up the lots.
What do you have for tires? are you chaining up?
05duramax073
Diesel Nut
Union Grove WI
They are just stock tires on the truck. I understand they are nothing more than highway tires, but it is a company truck and I had no say on how the truck was spec'd out.
If it continues to have traction issues have em kick down for a set of V links since you're stuck with bone stock street radials;)
no-red 6 0
Senioritis
southmetro MN
i got 4w and put 500# worth of sand bags in back and a 9' snow shovel up front and i could push a house. no issues. no complaints. stock everything...:sweet
no-red 6 0
Senioritis
southmetro MN
by the way, i only use 4 hi and have only used 4 low 3-4 times. way way too much low end grunt to plow with. feels like it drives like a D9, even though i have never driven a D9.:D
TacoCat
