Question Oil Consumption
JRJ04
Houston, TX
Oil consumption seems to be gone, however i need to verify that.
No, i have not checked the actual fuel pressure...still need to do that. would we be thinking its too high given my situation?
iracemine
black and tan
Cheese Curtain
or perhaps to low. Thats my next guess. If they changed all new injectors (should have changed cups too when in there), new turbo, but leaving residue on the bumper, new filters, but still puking out clowd of smoke with a hesitation Id say whats left?
JRJ04
Houston, TX
i need to check on the cups...is it possible one of those is cracked? wouldnt i notice something else if it were? how could i test to see if one was cracked?
JRJ04
Houston, TX
Update
Well, I finally got around to checking the fuel pressure yesterday casue I was under there replacing the filter.
I think my gauge got screwed up when some of the glycerine gel/goo leaked out, because I was only registering 34 lb of fuel pressure. There's no way that can be right...cause she's purring like a kitten.
does that sound right? Could my gauge be working right and thats really all im getting?
I think my gauge got screwed up when some of the glycerine gel/goo leaked out, because I was only registering 34 lb of fuel pressure. There's no way that can be right...[cause she's purring like a kitten.]
I'd say yer gauge has gone bad JR. If the glycerin leaked out.. something inside ain't right ? (the diaphragm ?)
JRJ04
Houston, TX
makes sense...i'll order a new one...cause it worked fine before. do you think low fuel pressure could be the casue of my issue? just seems like it would be too high or something along those lines (aka...the engine is getting over fueled, which would explain the nasty oily bumper.)
Don't know. We'd only be guessing.. until you get a Known fuel pressure, @ idle.
Over Fueling in a diesel is not the same as a gas motor. More fuel = more power. There is no such thing as running too rich, which can cause things like an oily bumper. Wait until you can get some reliable fuel pressures.
Jriltex
