nakahama001
just curious what the specs were on a 6.0-popcorn
F350DRW1 said:The manual says 15 quarts with the filter change. However, some of us have found 14 to 14 1/2 is better. 4 gallons seems a little high. If over-filled, you will foam the oil and can experience parasitic drag. [crank shaft is hitting oil]
