oil capacities
oil capacity for 6.0 & the 6.4 are the same...15quarts (empty...bone dry)
refill requirements vary & are commonly found to be some where in
the neighborhood of 12-13.5 quarts.
F350DRW1
Waylon Fan
N.J.
The manual says 15 quarts with the filter change. However, some of us have found 14 to 14 1/2 is better. 4 gallons seems a little high. If over-filled, you will foam the oil and can experience parasitic drag. [crank shaft is hitting oil]
Northeast Texas
and once its foamed up ypu can expect higher water temps to
all kinds of bad stuff starts happening
i usually get about 14 in after a complete drain
Deviant Diesel
Sooting 1 jerk @ a time!
Sanger, TX
So uh, F350DRW1, 15qts. is a quart shy of 4 gallons. . . just in case you ever poured in a full 4 gallons and had some problems.:innocent
NASCAR Mike
Richmond VA
I too add 15 qts of oil when I do an oil change....
I drain my oil when it's hot so most of it comes out.
