oil capacities
F350DRW1
Waylon Fan
N.J.
So uh, F350DRW1, 15qts. is a quart shy of 4 gallons. . . just in case you ever poured in a full 4 gallons and had some problems.:innocent
No, I haven't. There was an entry early on in this thread [that has since been deleted] that mentioned 16 quarts. I'm not the sharpest knife in the drawer, but thats pretty close to 4 gallons. So my reply is now out of context. :innocent
Mobeydick
Georgia
Book states 15Qt REFILL!! I put in 15QTs in both of my 6.0s at oil change. Never had a problem, even when one of my Employees put 16Qts in my 06. Put 10,000 miles on that oil change just like always!!
F350DRW1
Waylon Fan
N.J.
Well, there you go then. 15 quarts it is. Dipstick readings, foam problems, experiences other than your own be damned. 15 quarts it is.
bendog
Medford Or.
I been puttin in 3.5 gallons, runs great but Ill be dipped if I can tell accurately how much according to the stick. Wondering about sanding the dipstick for easier reading?
I filed a couple of notches/rings in mine...i cant say that it helps a whole
heck of alot...its a SLIGHT improvement.
bendog
Medford Or.
I even considered coating the stick with silicone lube or a flat paint. Maybe running a rifle swab down the darn thing before checking.
Mobeydick
Georgia
The "Dipstick" or lack there-of is the only thing I have called Ford and complained about!!
