Right is the passenger's side. The solenoid maybe on the starter and you can jump across the solenoid if you are careful. Have fun...
Clint... follow the passenger side + battery cable, it goes to the ignition solenoid.. mounted on the inter pass side fender. When you turn the key.. that solenoid connects/sends power to the starter motor and a solenoid that engages the flywheel (bendics spring)... which turns the engine over.
Sounds to me like..... If the starter motor is spinning.. but the engine is Not turning over.. you have a Starter Soleniod problem.
Shade-Tree.. but sometimes.. you can give the starter soleniod area.. a good Rap or 3.. and it [might] free up, and work [For A While].
11 year old starter soleniod & spring/gear/shaft ???
Ok. thanks big joe. I'll try to locate that and give it a few good taps. If it needs to be replaced, where is the best place to pick one of those up?
**Kinda yer call. I'm not a fan of remans.. I'd check with IH (not Ford) and see what they have and say ?
as far as the spring/gear/shaft you speak of, what exactly are those?
Have a great trip to New Zealand! It is wonderful down there this time of year.
Dave![]()
