(My f350 7.3 has had a cold skip for sometime now. Way back when it only skipped after first starting it when the temp was below 45. Now it skips if it has been setting for 10 hours or so and the temp is below about 75. Below about 30 it won't start at all. No smoke during cranking. No smoke after start. If I hit the road and mash on it about half throttle is like you flipped a switch and all 8 come to life and it is happy the rest of the day. Here while back it had set for several days and it was about 40 out. It started right up but was only running on about 4 cylinders. Mashing the throttle had little to no effect, just a rough idle. After a few minutes it would finally pull off. Got out to the dirt road, mashed on it, it coughed and pooted till it finally reached 1500 RPM and the switch flipped. Came to life and ran like a scalded cat. If I plug it in, no skip, starts and runs fine. It set for a week, went to it to use it in 75 degree day, started fine and was only missing on 1 cylinder. If I let it idle it takes about 10 minutes for the skip to go away.)
this is whats its doing to the T ... so... well he corrected the probelm with injectors ... so ... i think what i have to do is get a infa red gun and check each cyclender ...i think BIG problem is the injectors but maby liek cold oil would make it do it too or teh poppet valve that controel the oil flow to the injector maby it get stuck with cold oil ..this IS MY FIRST BIG PROBLEM OUT OF this truck and had since day off the lot ...ill post fromw hat i find out ... seems to be a problem with trucks about the 125 to 140 mile range ... k thinks you guys ..
