Missing/no power
let's check the cable from the battery to the GPR...
here's the source side battery terminal and connection..
O drop.. what we're looking for..
and the negative side OF THE CABLE, with it's reading..
.04 volts..
we're calling that a good cable..
OK.. so what is the drop across the low amp side of the relay?
hey..
that's a good coil winding
OK... now, what does the high amp and relay contacts drop?
NOTE: ENERGIZE THE RELAY!
.13 volt..
would hope it would be less, but still acceptable..
.25 volt across a contact, or .2 volt across a cable is good
we've got a good GPR and circuit here..
let's ohm a glow plug..
rut roh, Shaggy..
this one looks open...
let's hotwire the one that read OPEN and test it..
yep.. no glow..
now let's do the same thing to the one that read .7 ohms..
2 seconds to cherry...
good glow plug
to make a log story a shorter one, I had two junk glowplugs and the truck started HARD..
and ran like crap cold...
Thank YOU Mr. Dickmon.. for a REAL good tutorial :sweet:sweet
Should be a DYI/WIKI ??
spawt
