help ran out of fuel and ow my truck wont start
scheid6996
scheid6996
monroe,WA
ok thanks guys i got it runnen, just had to cycle the pump a few times, and i did replace the pump, i did the ITP pre tanl filter and pick up mod, it workes awsome, thanks denis at ITP diesel for all the tech info and for the fuel pump in the tank, there is none, the dumb guy at napa tryed to tell me the same thing, then i proved to him there want, there is a white mixing chamber that could look like a fuel pump, but its not, thanks all for your help
Black_Cloud_D
San Antonio, TX
You may have to reset the fuel cut off switch on the passenger side rocker panel below the glove box. If that doesn't work try disconnecting fuel line between the pump and the engine and turn the key on to see if you have any suction out the tank.
