Vindicator
Hi all,
Havent been here in quite some time now...Beast broke down a few weeks ago. Goin up a main street and I lose all power. Whattya know it, she breaks down right in front of the local Autozone. I go in and my friend there gets me a Motorcraft CPS. I change it and go on my merry way. Not bad for an original CPS goin 116k. Anyways, truck has been running great as of yesterday. I'm having a starting issue and I believe the glow plug controller is the culprit. Here's what happens: I place the truck in the ON position and the dash lights all flicker erradically and then I can see that the batt. indicator slowly drops to the 8 volt mark. I then thought I could isolate the GPC by unhooking the 2 plugs that plug into the GPC. Again, I turn the truck in the ON position, but this time the lights do not flicker and the batt. indicator stays around the fully charged mark. Does anyone know how to test one of these boxes? I can see that there is a thick gauge wire that stems out of one of the plugs that plug into the GPC. Should there be voltage at that terminal at all times or? Any info is greatly appreciated all.
