DT 466 rear main seal
uloadit
Swansea Ma 02777
i know this is not sd reading, but to change out the seal on the 466 is it straight forward. and do i need any special tools thanks
04Powerstroke
Ft. McMurray, Alberta Canada
You don't if I recall correctly. A seal puller would be nice though. The other option is to drill it, screw in a sheet metal screw and pull it out woth pliers or vice grips. It's just a one piece lip seal. Be sure to read either the seal or the box. Some seals state that it is to be installed dry.
dieselman44641
canton
I was an international mechanic for five years and have done a million of these remain seals and you are going to need a seal installer so that you dont mess up the rubber seal when going over the crank. Also when you go to pull the seal and you take out the rear oil pan bolts take a sharp scraper and seperate the seal from the gasket so you don't tare the oil pan gasket
uloadit
Swansea Ma 02777
I guess you can't get just the seal any more, i had to buy the hole plate because IH made it different seal
DragonSlayer
Pensacola FL
You will need a seal installer to do it, also go ahead and buy the rear main seal housing, it makes for a better job.....where do you live??? We have an installer at the shop.......
never mind, you are a long way from me......try to make a friend at the IHC dealer and borrow it. or check with some roadside repair folks:dunno
uloadit
Swansea Ma 02777
oooo yes had to get that too !! your not getting that seal on with out it ,i borrow it from IH and slip the guy $20 when i gave it back to him
TacoCat
