TampaDieselFX4
Checked my driveline angles today. I have a 4" skyjacker lift. I used a procomp carrier shim kit, b/c it allowed me to select in 1/16" incriments how much I needed. I'm running 7/8" of carrier bearing shim, which is PERFECT. the 2pc driveshaft is 0-.5*; as close to straight as you're going to get. the Tcase is down at 8* and the pinion is up at 12*!!!!!!!! That pinion is supposed to be 0-2* below the Tcase!!!! so I need some 4-6* of shimming on the rear axle. where can I get shims? ford? I know I don't want aluminum shims.
