corian countertops
Wood County Tx
Anybody know what type of drill or hole saw can be used on corian?
i need to bore a hole for the reverse osmosis faucet?
thanks
sagebel
Stock? Pfft!
Albuquerque, NM
You can use a hole saw. Make sure it is very sharp. It is highly recommended that you apply tape over the surface to be cut to avoid chipping. You can also get a solid surface blade for a jigsaw but it sounds like a pretty small diameter hole. Drill speed should be moderate. You want to keep the heet down. Let the drill do the work.
dpantazis
#12
under the cheddar curtain
how big a hole?
Corian and similar resin solid surfaces get worked with conventional tools. hole saw will be fine. consider running it in reverse to get it started.
a plunge router and steady hand is my choice for solid surfaces with.
if its one of the newer composites like the Zodiaq or Marmol, then it has REAL stone in it and you will need diamond tooling. best to bring it to a stone fab shop.
use plenty of masking tape or duct tape to protect the surrounding area.
I used a regular wood spade bit when I put the hole for my DI faucet in my house.
You need to drill slowly so you do not melt the plastic with heat from drilling. And it is best if once you get the initial punch through if you drill from the other side so you minimizie the chances of getting breakout when you go through (that or just drill with no pressure on the drill)
"Before we use any power tools, let's take a moment to talk about shop safety. Be sure to read, understand, and follow all the safety rules that come with your power tools. Knowing how to use your power tools properly will greatly reduce the risk of personal injury. And remember this: there is no more important safety rule than to wear these — safety glasses." Norm Abram
Yooper75
Boost Junky
Michigans Upper Pennisula
A regular hole saw can be used to make the hole and the only advice I can make is do it outside or have a fan in a window pushing air outside because when the bit gets hot it is going to stink to high heaven. I learned this the hard way when I remodeled my house.
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
Safety with power tools can never be overstressed. :pb:pb
Dewalt Power Tool Safety Video
:lmao:lmao:lmao
Yooper75
Boost Junky
Instructions, we dont need no steenking instructions!!!:tounge
zr1pete
Florida
Bama, "YOUR FUNNY":hail:hail
Brad1103
