corian countertops
Masking tape over where you want the hole, wear safety goggles,[drill a pilot hole], then a good sharp hole saw.. let the hole saw do the work.. Done deal.
Wood County Tx
thanks guys
bama thanks for the safety tip :lmao:tounge
its only 1.5 " hole so i will go slow and let the drill do the work
i got more honey do's right now than I can get done :dunno:eek:
Scooter
Mesa, Arizona
You can use a hole saw. Make sure it is very sharp. It is highly recommended that you apply tape over the surface to be cut to avoid chipping. You can also get a solid surface blade for a jigsaw but it sounds like a pretty small diameter hole. Drill speed should be moderate. You want to keep the heet down. Let the drill do the work.
I guess that means that the plasma cutter is out???:innocent
Owning an RV is EXACTLY like owning a PSD..... The Mods, Improvements and "Better Ideas", Never Stop. :D;):lmao
Wood County Tx
success
drilled two holes, nice and slow let the chipps curl and in about ten minutes we were through
thanks guys
tg...the list just gets longer at every turn,
at diner tonight we took measurement to have some cabinets made for the dining area ;)
i got to do something about that UGLY tailpipe
spawt
