Ok, I can't find the write-up and until Kevin gets back I can't get it (march 4th)
, But here's the description in a nut shell:
It's a black plastic box about 8" x 8" and has 8 switches that are numbered 1-8. It has an attached bundle of wires (16 of them) that goes from the black box to the main harness on the driver’s wheel well. We got a stock male and female connector form a harness at a junkyard, we then turned the harness connectors backward and spliced into them to make a "T" so you can unplug the stock harness and insert this plug so everything will operate normally.
From the "T" all you have to do is cut each of the 8 injector wires and run 1 end of the wire up to 1 switch and then run another wire from the switch back to the "T" to connect to the other end of the injector wire, this is so you can break the connection with the switch to turn that injector off.
I'll try and get a better write-up for you guys and maybe some pics.
JIM
I attached a drawing that I made using MS Paint, I think I set the Art world back a few hundred centuries
