6.0 running rough, no throttle, no hot start
04gold60
US
When you have an injector leaking combustion gas, it usually takes out all the injectors on that side. It would seem that at a minimum you need all new injectors on the passenger side. If they have very many miles on them, then it would be wise to do all 8.
My thought was more I have no idea on the miles on the injectors and I don't want to do the passenger side or one injector and then have to tear it apart and do more.
I just hope I am right on with the diagnosis I can't think of anything else it could be
Sent from my LG-M322 using Tapatalk
bismic1
It sounds right to me, but I always have to remind folks how hard it is to diagnose things without actually having the truck "in hand". That said, low fuel pressure, inadequate flow, or air will quickly ruin all injectors.
04gold60
US
Well now to shop around and hopefully get some that work for a good price
bismic1
You can get OEM remans on-line at AutoNation White Bear Lake (a dealership) for around $180 each. Not sure where the best price is for the new Pure Power injectors. They will be a little more IIRC.
04gold60
US
Trying to update everything here, I solved my issue, ended up replacing all 8 injectors with a set from Warren Diesel with new spool valves, there is a world of difference how these buzz vs the previous injectors.
So far it's been 3 weeks and no problems yet(knock on wood) it's runs really good.
And I had no real signs pointing straight to injectors, the only thing I ended up having at startup was a rough idle and a little plume of black smoke.
To anyone else fighting issues like this good luck to you, and FORScan Lite and Torque Pro are your friends.
bismic1
Thanks for updating! You have sure been through a lot of issues in the last 3 months, but (as I posted previously) good job sticking with it and not getting (overly) frustrated! Injectors are expensive and because of it, hard to pull the trigger on. A person really needs the dealership IDS system to test them, but your persistence got you the win!
Oh - and keep an eye on that fuel pressure. Dropping to 50 psig is ok, but it is getting to the lower edge of what you want to see. Low fuel pressure and/or poor fuel flow will quickly kill injectors! I periodically check for bubbles in the fuel as well as monitoring the pressure. Early detection is the key to minimizing the spending!
Time to enjoy your truck!!!
