dogtrk
Pat
the vac. pump (which is mounted under the hood, in the engine bay,
on the passenger side fender)...provides vac. for the ac/heat/defrost
venting as well as for the auto hubs.
if there is a LEAK in the vac lines the ac/heat/defrost DEFAULTS to
the defroster.
when you cant control/direct the vent (ac/heat/defrost) its typically
an indication that youve got a vac. line/pump leak..and its more often
that not a leak at the hub seals which prevent the hubs from locking or
unlocking (automatically).
the HUBS are some what independant of the transfer case... the transfer
case can be engaged w/OUT and the hubs might not BE locked/unlocked.
Tomorrow I have someone coming who knows how to test these things so we'll start there.
I checked all the vents last nite and warm air was coming thru all of them as well as the defroster vents.
One thing I do remember is that when I bought this truck the previous owner had installed a remote starter but it was pulled before the truck was sold. Don't know if they may have damaged anything when they pulled it since I don't know where it would have been located. Good thing my new book on diesels is coming today!!!!...that should help me a little.
Soon as we do the testing I'll be back.......
I do want to thank you Bush for all your help so far and everyone else who has responded. It's certainly been an education and hopefully we can get this resolved without me having to go to the Ford dealer.
