PART ONE
OK, here it goes. i will try my best to keep it simple. some of the steps are fairly strait forward, if i can do it, then anyone can
First of all here is the parts list of what i had to order that i could not use from my old tailgate, with a picture below the part #.
Part Numbers with Pics
1. Driver's Side Roller (hinge) - 4L3Z83430B39AA
Note: This part is a F150 part number
List Price = 6.83
![](/proxy.php?image=http%3A%2F%2Fthumb6.webshots.net%2Ft%2F57%2F757%2F9%2F69%2F40%2F2313969400096894966ZQnyhG_th.jpg&hash=166aac6d80f739ba657ef48ca9f09853)
2. Insert - E7TZ99430B22A
Note: Under this part #, you get the insert and the washer(shim)
List Price =7.58
![](/proxy.php?image=http%3A%2F%2Fthumb6.webshots.net%2Ft%2F59%2F559%2F6%2F81%2F29%2F2142681290096894966TNgOOT_th.jpg&hash=2eff73cce34a56e1d258ff8a428c122d)
3. Door Handle - 8L3Z9943400AA
Note: This is also the same handle on the newer F150's
List Price = 28.78
![](/proxy.php?image=http%3A%2F%2Fthumb6.webshots.net%2Ft%2F59%2F559%2F6%2F59%2F35%2F2722659350096894966DwRfvD_th.jpg&hash=a0019fe150a989189f4026ab40496500)
4. Ford Name Plate (Emblem) - 8C3Z1542528A
List Price = 25.12
![](/proxy.php?image=http%3A%2F%2Fthumb6.webshots.net%2Ft%2F57%2F657%2F9%2F64%2F7%2F2968964070096894966ggjjnW_th.jpg&hash=2d4f3a2c291bad3fe19ac561f85042c2)
5. 2008 Tailgate Cap/Moulding - 8C3Z9940602AA
List Price = 30.33
![](/proxy.php?image=http%3A%2F%2Fthumb6.webshots.net%2Ft%2F53%2F453%2F2%2F24%2F23%2F2918224230096894966XsFfxL_th.jpg&hash=0eb4cacfa149192b70e33fb228d34a2a)
6. 2008 Non-Step Tailgate Assembly - 8C3Z9940700A
Note: The cover that goes over the locking mechanisms is sold seperately
List Price = 305.68 (I paid 229.26
![](/proxy.php?image=http%3A%2F%2Fthumb6.webshots.net%2Ft%2F59%2F459%2F6%2F57%2F71%2F2482657710096894966vBBkgs_th.jpg&hash=d1deab3aeeb7f6b249ba056b97e7f572)
OK, thats the parts who will need to order.
I had to order a new cover because the other one was no good, and you can reuse the one from your original tailgate, but here is the part # if you need it.
Cover - 8C3Z9943121A
Now for the install, and please hang in there with me, i believe it will be worth your while.
First of all, keep the original roller/hinge on the pass. side
![](/proxy.php?image=http%3A%2F%2Fthumb6.webshots.net%2Ft%2F59%2F759%2F2%2F89%2F9%2F2700289090096894966oZGYda_th.jpg&hash=d65fd1ba9106ca2e0f47a6d96d5956b6)
Next, install the new roller/hinge on the driver's side, make sure you put it right back where the original one was, unless you need to make adjustments when you have everything together for a better fit.
![](/proxy.php?image=http%3A%2F%2Fthumb6.webshots.net%2Ft%2F57%2F457%2F4%2F32%2F91%2F2529432910096894966qBhLig_th.jpg&hash=ed5c478d9d64e647a9e3bbffdc295218)
Along with the 2 steps above, i want to show the matching part on the tailgate that will go into each of the 2 roller/hinges
Driver's Side of Tailgate Assembly
Pass. Side of Tailgate Assembly
Next, I installed the 2008 tailgate handle, the original key cylinder, and the original open/close mechanism from my old tailgate.
Note: It was easier to install the key cylinder after you have the handle in place and before you put the open/close mechanism on.
Note: I found that the original locking clip kept the cylinder in place better than the one that came with the 2008 tailgate handle.
![](/proxy.php?image=http%3A%2F%2Fthumb6.webshots.net%2Ft%2F53%2F553%2F4%2F59%2F89%2F2540459890096894966VZUWTj_th.jpg&hash=fb4c287299aaa62aef654faad3a00e07)
List Price = 6.83
List Price =7.58
![](/proxy.php?image=http%3A%2F%2Fthumb6.webshots.net%2Ft%2F59%2F659%2F3%2F5%2F24%2F2038305240096894966AsYeDM_th.jpg&hash=67465ea9f8c5fe52be7f765ae246968a)
![](/proxy.php?image=http%3A%2F%2Fthumb6.webshots.net%2Ft%2F59%2F559%2F6%2F52%2F7%2F2512652070096894966hdUHUn_th.jpg&hash=4de6b55e362c255fb913e485f7568298)
List Price = 28.78
List Price = 25.12
![](/proxy.php?image=http%3A%2F%2Fthumb6.webshots.net%2Ft%2F53%2F553%2F3%2F15%2F23%2F2951315230096894966qFVayS_th.jpg&hash=aa279bdda4f0434fcc47801305e4c7f2)
List Price = 30.33
![sly :sly :sly](/styles/default/xenforo/smilies/graucho.gif)
![Sweet :sweet :sweet](/styles/default/xenforo/smilies/Thumbup19.gif)
![](/proxy.php?image=http%3A%2F%2Fthumb6.webshots.net%2Ft%2F53%2F553%2F5%2F53%2F75%2F2178553750096894966LKxxzc_th.jpg&hash=9913e5b4e31489c75b274cefab48b031)
![](/proxy.php?image=http%3A%2F%2Fthumb6.webshots.net%2Ft%2F57%2F657%2F7%2F54%2F41%2F2491754410096894966bvhOdV_th.jpg&hash=707c595c00179f7dc8ed5aa1f6bf878b)
![](/proxy.php?image=http%3A%2F%2Fthumb6.webshots.net%2Ft%2F59%2F659%2F7%2F81%2F52%2F2106781520096894966AEPKnF_th.jpg&hash=3be800de2bd1e8a63c9205453869b637)
![](/proxy.php?image=http%3A%2F%2Fthumb6.webshots.net%2Ft%2F59%2F559%2F4%2F22%2F46%2F2824422460096894966EkkdIO_th.jpg&hash=b07f4be2f2a73ff3bf2d030ab495fbf1)
