sagebel
Stock? Pfft!
Those with OBS trucks that have dual tanks could easily heat one and use it for WVO and then use the other for #2. There are a few trucks out there that are running this way or have a separate tank mounted on the truck someplace. You start up on #2 and when the veggie gets warm enough (around 170*) you switch over. You can use coolant to warm the oil. There are a few places where you can buy heat exchangers. You will want to filter the oil down to 10 micron or less. The lower the better. I am filtering my bio diesel down to 5 microns using a $9 Napa filter. I will try to post the part numbers tomorrow.
Scott
Scott
