Ran across this thread while in the TDI forums,he was doing something wrong or the engine was botched when he bought it
LINK
LINK
2) Where did all the sludge come from?
AMAZING --->
If WVO messed up your first turbo, then what messed up your second turbo? What damaged the blades on the new turbo so quick that needed replacing again? ........
It is suspected that oil ingested through the CCV is what damaged the new turbo. That excessive oil injestion was due to the extremely high crankcase pressures caused by the piston blowby. Oil droplets striking the turbine blades at full speed can wear away metal.
