Wiring harness FIX for the UVC pigtails that burn!!!
bbressler
Happy, TX
These go into the UVC gaskets and control injectors and glow plugs.
There are four of them, two on each side.
Here's the rear one on the pass side..
97 CREWCAB
OBS RULES!
Dunkirk, MD
Ro,
You dont really need a "special tool" to pin these or any plugs of this type. If you carefully remove the pin retainer (should be a different color than the plug material) you can use a paper clip or a safety pin to release the lock tab on the pin. If you put a little pressure on the wire and pin towards the mating eng before you release the lock, it will come out easier. Also helps if you have good eyes and a pen flashlight to see which way the lock releases.
Jim
