Whinning noise 06 superduty
htg900
Kalamazoo, Michigan
I have 06 F250 6.0 truck has whinning noise coming from drive train I think cause I put in N when driving and noise is still there. Have owned truck since new it has 41k on it. Any suggestion o n what noise might be?
Thanks Mark:dunno
Northeast Texas
can you be more specific
is it a like a tire whine or high pitch whine like a MIL at a bakery looking at day old bread :sly
or is it a lower tone whine like a rear gear
or a mid pitch
is it varied at speeds or does it stay constant?
if you sit in nuetral and stopped and rev the motor does it come back?
htg900
Kalamazoo, Michigan
IT is a mid pitch whine if I had to guess it kinda sounds like a noisey bearing. I know it isn't tires or power steering.
rynarnell
03 6.0 8.0lift on 38"s
alaska
id say carrier bearing, or the pinion gear bearing isnt preloaded right.
htg900
Kalamazoo, Michigan
Took truck in and whinning was a bad pinion bearing 40K miles and chrome was comming off bearings. What ever happend to " Built Ford Tough" ???
TacoCat
