Mike K
يساعد المعركة لحرية
Ok, i have narrowed my search down to two trucks.
My first choice
03 F350 CC DRW 7.3L 4x4
• $?? still havent contacted the dealer
• 82,411 Miles
o The last 40K miles have been a registered fleet truck
• 10K miles ago was in a small accident (driver turned too early in a dairy queen drive through)
• 4x4 – not sure if a good thing, probably wont use it
• 7.3L Diesel
• According to FlatRateTech.com the OASIS report had: had friction modifier added to rear end, mirror glass replacement for falling out, two tires for bulging, oil leak at high pressure pump (orings), the accel pedal sensor recall was done, a rear main seal, a high pressure oil pump, and 2 injectors (1 and 3).
I really like that it is a 7.3L but i really dont like the 4x4. I plan on moving to Forth Worth, TX and my play toy is the mustang so i dont plan on going 4 wheelin'.
Runner Up
03 F350 CC DRW 6.0L 2 wheel drive
• $30,914 (haven’t contacted dealer yet)
• 47,289 miles
• No accidents, CARFAX came up 100% clean
• OASIS: The fuel injection control module was replaced; the turbocharger was replaced, the right front window regulator was replaced, it's had an alternator replaced and the PCM has been reprogrammed a couple times. No open campaigns.
I like that it is 2 wheel drive but not sure about the 6.0L.
So what do you guys think? The truck will be used for a daily driver and as a tow vehicle. As a matter of fact as soon as i buy it i will use it to tow my Saleen from Delaware to Missouri so i can sell it. Then when i get back to the states for good (i work out of country) i plan on moving down to TX - so once again the truck will be used to tow my current Cobra as well as my tool box and other stuff. Other then occasionally towing my Cobra around it will be a daily driver to and from work.
Any and ALL comments are welcome.
-Mike
*EDIT* What do you think is a fair price for each truck?
My first choice
• 82,411 Miles
• 7.3L Diesel
Runner Up
• 47,289 miles
-Mike
