Which performance chip is better?
CSIPSD
Bend, OR
TS is who makes the chips everyone use's. They also have there own burns. I had a TS chip, about three years ago... With there hot fuel 7. Fast but hard on components. There stuff is a little older the some of the others mentioned.
DI is Diesel Innovations, David Lott. One of if not the fastest 7.3 PSD
lukecline
Kansas
ward cleaver said:
I have a 97 4x4 7.3L powerstroke with K&N air filter and a bullydog 3" down-pipe +
cat "test pipe". Which chip is better for performance/safer (lowest egt's),
Edge EZ or Bully Dog 6-Position 4-Bank Chip for Ford Powerstroke?
I tow a 30' 5th wheel toybox 14,000lbs gvw.
Tony Wildman is the best tuner for the older trucks hands down. www.totaldieselperformance.com
ward cleaver
Californication
ok, so I'm thinking hard bouta tony wildman 4 pos. chip w/
*No start - *60HP tow - *80HP economy & *100 performance.
What do you think my rwhp will be in the 100 mode? I'm gonna get an AEM 21-2059DK filter to replace the K&N, + a 4" cat-back exhaust and pyrometer. (I don't have aftermarket injectors yet) What do you think?
lukecline
Kansas
with stock injectors you'll max out at 225-235 rwhp no matter what until you get larger injectors.
luke
ward cleaver
Californication
Ok, so I talked to Tony Wildman and I guess this is all I can get out of this truck without the injector mods:
*Stock - *25HP economy - *45HP tow & *75HP performance
I'm trying to decide whether I need a stock setting or the no start.
What do you think?
lukecline
Kansas
hmm bout 3-4 days shipping probably. Takes aobut 5-10 min to burn chip and as long as you dont want a bunch of custom programs then its pretty qick.
