Water in Fuel light REVISITED
Northeast Texas
whatabudro said:
quit puttin that watered down whiskey in your tail pipe and you won't have a problem:D
you know i heard diesels will run on anything :roflmao :roflmao :roflmao
maybe we need a new fuel source like BUD :D
Northeast Texas
new ones are going in on saturday, I have less than 1/4 tank and i am trying to burn down to the low fuel light and maybe drop the tank saturday and clean it out, poon it and put in a drain plug.:D
the crapp i drained last night made me nervous it was gellin up so we got some critters growing in there, which means we also still have a ton of water.
this is starting to get $$$$.
now if i can find the instructions on dropping the tank, its been awhile
roosterdiesel
Earl needs B100
Amarillo,TX
Well if it's not any different than the 7.3s you can look in the Wiki.:D
May wanna get some critter killer too!
Just a little FYI I found out with my experiences and talking to the bio distributor from Denton, the algae is white and the black pepper looking stuff is the excrement from it.
Northeast Texas
my gelatinous substance looks more like clear silicone does when gasoline hits it,
wonder if the powerservice additive is making it congeal into a gelatin.
i will go read the wiki.
joy joy, a bath in #2 fuel
ranger boy
Banned User
I gotta drain mine too. Haven't done it in forever.
I don't know what diesel looks like so I dunno when to stop draining. Can anybody help me out a little bit? Can't wait for my bath in #2.
Northeast Texas
drain it till it quits draining... about a 3/4 of a quart.
#2 is a yellowish green amberish color, you know like Straw :D
did you get a lcf drain plug yet????
6E7Z9C082A
order here
it makes it so much easier to drain.:sweet
99RedTA
spoolin up
South Carolina
powerboatr, i had this problem about a month after i got my truck. I drained the fuel from the little block past the fuel filter under the truck. Did this several times. WIF light would still come on after a day or so. Then i took the face plate off of the little block, picked all of the junk out of the bottom of it, gave it a good cleaning. Then changed the fuel filters. Hasn't been a problem since. That was about 9 months ago. Also you'll need a new o-ring for the face plate. Hope this helps.
Northeast Texas
its fixed
several gallons of fuel drained and filters changed.
I drained , repressurized and drained again over 12 times.
new filter , shot of powerservice, pumped in 27 gallons of fresh fuel
i cleaned out about two table spoons of gelatinous gunk and sand from the tank and filter head.
we shall give here a week and see?
ranger boy
Banned User
6E7Z9C082A
order here
No Drain Plug. I have no credit card.
FlorWhitfe
