Help Needed Very Strange No-Start
rdrancher
Denton, Texas
This morning when I put the key in the bell range as usual (ding ding ding etc.).
Turned the key on for glow plugs, warning lights on, ding-ding-then "ready" ding - everything normal so far.
Turn the key on to start - one slow crank then a couple of clicks and warning lights flash off and on momentarily - then nothing. Just like a dead battery.
Turn the key off.
Turned the key on for glow plugs - warning lights flick on momentarily then off - no ding-ding-ding.
Turn the key off - Something under the dash starts clicking like the ding-ding-ding but it's a click-click-click.
Remove key - click keeps on going. Key back in - click keeps going.
Tried starting several times - nothing but the click-click-click.
Remove key - click keeps on going. :confused:
Turn headlights on - click turns into ding again.
Turn headlights off - ding stops.
Put key back in - ding is back as normal - glowplugs/dash warning lights as normal - truck cranks as normal and starts fine.
Several more tries - everything normal.
Unfortunately my batteries are out in my voltage meter too so checking batteries, etc. was not possible.
Maybe a coincidence, but the night before I changed a rear brake caliper and pads all around with the associated bleeding proceedure. The hood was open for quite awhile with the underhood light on.
I did start and move the truck after the brake job.
Batteries are less than 2-months old.
I'm at a loss - Any ideas?
rd
diesel patriot
ofallon,mo
I would say bad connection also if the Batteries are good. It does sound like a voltage problem though. A '92 ford I used to have had a glove box light that stayed on and would drain the battery after about 5 days if the truck wasn't driven. It took me several batteries and lots of headaches to find that one. The truck was only a couple of months old at the time.
rd have you pulled the alternator and had it tested at like autozone? Might want to clean all the posts and clamps to be sure.
Wishd I was nearer I'd swing by to see what I could do as I went thru the battery/alternator deal a month or two ago:rolleyes:
