upfitter switches
hey bush-
i see you can't follow the pencil lines... gotta get out the eraser...:sly
just crackin on yah....:sorry
you know i was in such a hurry to take the photo (couple yrs ago)
id forgotten that the reference line was there (it was dark when i
finished...and i said the hell w/ it after i posted the photo).
the perspective of the photo might make it look like the switches
are a bit "off"...but they are straight.
whats worse is that pencil line was HARD AS HELL to get off that
textured plastic...i was cleanin' the interior the other week after i
had the alignment checked and i noticed there was STILL some pencil
mark (its like freekin' cement on there now i guess) !
danegreen
Northern New York
Thanks
Thanks all for sharing your modifications with me. It seems the high idle is one of the more popular mods. Is this an aftermarket kit or something you have designed on your own?
bears4x4
grease monkey
katy texas
where can one buy those upfitter switches that bush has installed, i have some smaller ones in my truck and i dont like them to much, i would like a more factory looking set up.
Switches and actuators can be viewed here: Switches pictures from cars photos on webshots
Prices:
SPST (ON-OFF) or DPDT (ON-OFF-ON) switches with a green light and a red indicator light $8.00
DPDT Momentary (ON-OFF-ON) NON LIGHTED switch: $6.00
DPDT Momentary (ON-OFF-ON) LIGHTED with green only, no action light $8.00
SPST Momentary (ON-OFF) with green light only, no action light: $8.00
Actuators: $3.00
Single, end, or middle brackets: $1.00
3 mount bracket: $2.50
6 mount bracket: $5.50
Bracket Plug: $0.75
Removal tools: $.50 ea (recommend 2)
Living in Alaska my shipping options are limited. I can only do priority mail and you should receive a shipment in 3-7 days depending where you are located.
You need 1 actuator per switch. You do not need a mounting bracket, but makes for a cleaner and easier install, especially for multiple switches.
I Prefer payment threw Paypal to my e-mail addy of [email protected]
Currant Actuators available
ACT101 Head Lights
ACT102 CL/ID Lights
ACT103 Trailer CL/ID lights
ACT104 Driving Lights
ACT105 Fog Lights
ACT106 Backup Lights
ACT108 Power Window
ACT109 Engine Fan
ACT110 Mirror Defog
ACT111 Mirror (In and Out)
ACT114 High / Low
ACT112 Engine Brake
ACT118 LH/RH Tank
ACT121 Beacon
ACT124 Idle Speed
ACT202 Air Axle
ACT204 Mirror
ACT205 Marker
ACT206 Flood
ACT209 Dump
ACT210 Tailgate
ACT215 Rear Flood Lites
ACT216 Hyd Pump
ACT218 Body Lights
ACT220 AUX Heater
ACT221 Webasto
ACT225 Idle Shutdown Override
ACT328 0/0 Lights
ACT329 Alarm
ACT330 Mobile Phone
ACT331 Tire Chains
ACT332 Engine Warm up
ACT333 Fender Marker
ACT334 (pic only) Engine Warmup
ACT335 Spare
ACT336 Trailer Backup
ACT338 Rack Lights
ACT339 Fuel Heater
ACT341 AUX
ACT344 RACK
ACT345 Load Lite
ACT346 Work Lights
ACT347 Tank LTS
ACT348 Power Take Off
ACT000 Blank
screamineagle
screamineagle
Green, Ohio
#1 Rear bed lighting
#2 Unused
#3 Rear back up camera for truck and fifth wheel
#4 Front driving lights mounted on Westin grill guard.
screamineagle
screamineagle
Green, Ohio
danegreen: I installed this setup which takes three cameras. I am putting one on the rear of my 5th wheel when I get it out of storage. This comes with two 30' cables and I also ordered an add. 60' for 5th wheel run, as well as an additional camera # 1085 for rear of truck. There is actually a small hole already drilled in rear bumper to the right of center that only has the plastic covering it. I used that. Works great. Look at this site and check accessories for the additional camera I bought. They were the best price and warranty,
Professional Design 7"LCD Backup system
....There is actually a small hole already drilled in rear bumper to the right of center that only has the plastic covering it. I used that.
got any photos of youre monitor and camera install/mounting ?
you didnt block the hole in the bumper thats used to lower the
spare tire did you ?
FlorWhitfe
