powerboatr said:upfitter
05UPFITTERSWITCHKIT Each $111.54
$82.31
Complete kit to add Factory Upfitter switches to 2005 and newer
You will recieve the all of the following. A complete kit to add the Factory Upfitter bank of switches to run whatever accessories you like onto your 2005 or newer Superduty.
1- bank of On/Off switches fits into existing panel on dash no cutting or drilling required.
1- Complete harnes with plugs to plug right into the fuse panel, you also get all of the necessary relays and fuses installed in the block which is integrated into the harness.
install
it would be an easy thing to do to hook em up.
you just provide four fused circuits and tie it into the piece that would normally plug into the fuse panel
It would be hard to do at all
you the man robert. mr. copy & paster of the year. good post.
