TRUCK WONT START NEED HELP FAST
BigHog
ok well first things first i have 2000 F250 and the other day i was driving and my truck died. so first thing i tought oh must be the cps. so i went to start it again no joy. so i replace the cps on the side of the road still no joy. so i get it towed home to fix it later. well i thought well the batterys have been giving me a hard time so maybe thats it. so i got two new batterys still doesnt work. so now i thin its a fuel problem because i drained the the fuel/water sep and turned the key on and no fuel can in to the housing but the pump is still working or at lest sounds like it and feels like it. so please help me thanks a lot
:thanks
You'll want to verify that the pump indeed is working by attaching a length of 3/8" or 5/16" hose from the outlet(forward connection) with the hose running to a gallon jug.
Turn the key to start and if fuel doesn't come out it'll be the pump or the pickup/mixer/filter screens in the tank is clogged up preventing fuel flow or the line from the pump to the tank has become disconnected.
From the pump to the fuel separator I can't see any obstructions.
Others will check in with their fuel system savvy:cool:
94f450sd
certified nutjob
plymouth,ma
also how much fuel in the tanks?the super dutys have that stupid little rubber thingy on the end of the pump in the tank wich can and does fall off and cuz the truck to run out of fuel at 1/4 tank.
94f450sd
certified nutjob
plymouth,ma
ok then check all the fuses under the hood and dash.like was said if the fuel heater shorted out it will also kill the injection system
XTrmXJ
NACHHOOOOOOO!!!!
Hampton Va
Does your WAIT LIGHT come on when you turn the key? If it doesnt then its a big fuse under the hood, when that fuse blows it means that your fuel preheater grounded out
BigHog
yes my wait to start come on and im about to go out side to check the pump
BigHog
ok well i dont know how to take of the hose to the fuel pump so i need someone to tell me how and i also want to know what this is because its been making a load cllicking noise i dont know if this have anything to do with why my truck wont start
FlorWhitfe
