Help Needed Truck will start then starts sputtering and blowing black smoke until it warms up!
dirtndrums
gaffney sc
I have a 2005 F350 6.0 with a 2006 engine in it. When I crank it after it has been sitting for at least 6 or 8 hours it sputters and shakes and blows black smoke out of the exhaust pipe until it warms up. After it warms up it runs just fine no matter how often I turn it off and restart it, even 4 hours later. If I turn it over and let it sit a couple extra minutes before cranking it, it doesnt do it as bad or at all????
FordFarming7
Rockingham,N.C.
Almost the same exact problem I had. I changed the fuel filters and the EGR valve but the problem ended up being the icp sensor.
2 Stroker
Warren/Oregon
I have a 2005 F350 6.0 with a 2006 engine in it. When I crank it after it has been sitting for at least 6 or 8 hours it sputters and shakes and blows black smoke out of the exhaust pipe until it warms up. After it warms up it runs just fine no matter how often I turn it off and restart it, even 4 hours later. If I turn it over and let it sit a couple extra minutes before cranking it, it doesnt do it as bad or at all????[/QUOTE
weak or bad batteries will kill the FICM i would check it.
Ford 6.0 FICM Testing & Removal Instructional Video - YouTube
2 stroker
pizzaman11
illinois
i just had a very similar problem with my truck. i had to replaced the FICM and injector #4. i also noticed when i was having these problems that my power was being effected, the truck was a dog. so just something to look at.
GGJPGUY
Yuma,AZ
Both of mine started doing the exact same thing, it was the FICM.
