Same Issue!!
I just logged in to post having the same issue!! I pulled into work, a lower level parking garage, and the trucks gauges went dead and and no throttle. I have a 2001 F250 with a 4in lift on 35's. I was dreading a phone call to a tow truck driver and explain to him how to get my truck out of the lower level garage! I will play with the tilt column, shift handle and turn signal. I hope I can remedy the problem.
Does is normally blow a fuse in the panel? If so which one and what is the placement? This forum has saved me lots of headhaches so I appreciate your help.
Wes Whitley
