Truck starts no gauges no gas pedal
songdog
Fresno CA USA
I just logged in to post having the same issue!! I pulled into work, a lower level parking garage, and the trucks gauges went dead and and no throttle. I have a 2001 F250 with a 4in lift on 35's. I was dreading a phone call to a tow truck driver and explain to him how to get my truck out of the lower level garage! I will play with the tilt column, shift handle and turn signal. I hope I can remedy the problem.
Does is normally blow a fuse in the panel? If so which one and what is the placement? This forum has saved me lots of headhaches so I appreciate your help.
Wes Whitley
Wes take a look at fuses 46&47 if that is the problem then the OD wires in the shift lever are shorted if the fuses are ok turn ur head lights on with the highbeams and see if that works keep me posted to much to type maybe call me and I could help
Brad1103
