Truck just cranks, never turns over
forumpete58
Kansas City, MO
A friend of mine hooked up a chip to his truck, now the truck just cranks but never turns over. What do we do?
Thanks!
melmount
greensboro nc
i had a bully dog do that once. It lost the original program(sort of) the computer did not recognize the motor or something. So it would not start. Bully dog took my vin made a new program. i downloaded to the programmer then the truck. all was fixed. I can explain better if this sounds like a possibility?
what chip?
roosterdiesel
Earl needs B100
Amarillo,TX
Yeah, even with the chip out it won't start...just cranks
Yes it ran before installing the new chip
Were the batteries connected when he pulled the PCM to clean the contacts? Were the key in the ignition when the chip was installed? Do you get a WTS light?
If keys were in the ignition he may have fried the PCM.:sorry
rgkesar
morristown IN
1999 f250 sd 7.3
i i did the samething i installed a bullydog 6 p chip on my truck works great one day i was installing lights on my truck working under the dash and pulled on the wires to the chip chip came out of pcm o**** reinstalled chip no wts light no gpr no fuel hooked up scanner got a error fail to read out 400.00 for reman pcm allways unhook battery no matter what
Ricksofla
