Tranny not shifting
f100cleveland
When In Doubt,THROTTLE ON
Southern Minnesota
The other day I put the selector in the 3 position and the truck takes off in 3rd gear. I tryed the 2 position and it takes off in 2nd. It shifts normal in overdrive. Is this the way it's designed to work?
fordtrucker4life!
I work with waste
SE Michigan
I read in a previous post that, that is the was it works. I had a 99 F-250 gasser that would start off from 2nd if I passed drive.
f100cleveland
Southern Minnesota
I know the c-4 and c-6 tranny's would start in 2nd for less wheel spin in slipperry conditions but a 3rd gear start seems strange.
f100cleveland
Southern Minnesota
I called the ford dealer and talked to the service dept. and I guess it's one of fords better ideas. Well at least it's not broken.
TacoCat
