Tired of LOUD "engine" Noise!
Crusin350
D Dub
Troy, IL
I Bought my truck about 2 years ago. I noticed the truck had a loud engine noise when I bought it, but wasn't too worried about it. But it seems more and more people (mostly mechanics) are telling me that it sounds bad. It is extreamly loud at idle (nocking or clanking) and seems to quite down when accelerating or raising the rpm's. I think I have eliminated it to one of three things, tourqe converter, transmission bearings, or rear engine bearings. There are no oil leaks or trans. fluid leaks (not even residue on the underside of the vehicle) I removed the flywheel cover about a week ago and noticed what may be a slight shimmy in the flywheel (or maybe it just appears to be one with the shaking of the engine). I was wondering if anyone has ever had any similar symptoms, or would know what it might be.
Thanks!
PS it sounds like an old school bus with the T444E.
I think the 99's have always been distinctively louder than newer 7.3's I can hear a noticeable difference and I've never heard of anyone have problems with it, rather thats just the way it is
Crusin350
D Dub
Troy, IL
That was always my thought (sounds like a commercial truck) but Im begining to think it is getting louder (could just be my imagination).
Tbar
SDD STAFF/Moderator
You might be hearing the infamous "engine cackle." If so........a whole lot of band width has been consumed over the years cussing and discussing this issue.
Tbar
hheynow
Señor Aceite de Soja
Northern California
Did the noise get louder since USLD was introduced? Try using a 20% blend of biodiesel (B20). Mine runs quieter on bioD than on #2 (which I don't use anymore).
Tbar
I'm with Tbar on this one.
Although Richard has a point with the bio-fuel. My truck quieted down A WHOLE BUNCH when I switched from ULSD to B20
Russ
Found On Russ' Drive
New Brighton PA
Early 99's are well known for TC issues. The "goes away under acceleration" is the give away. That's where I put my money.
dzl_x_4x4
Dzl_X_4x4
Rowlett, Texas
On my 2000 X 7.3 I used to have neighborhood kids run down to the street when they heard me, thinking I was the bus. I used to have fun in the morning messing with the little stinkers. When I installed the HX crossover mod ($45) it quited mine down alot, The Ford mechs. even asked me what I did. But with the ULSD I add lot's of Lucas since I can not get Bio anymore.
69oiler
I don't feel tardy
NE OH
my money is on the torque convertor. i had the same problem. the noise goes away when the TC locks up. you hear it come back when coming to a stop when the TC unlocks. at idle it is deafening.
