timing gear covers?????
94f450sd
certified nutjob
plymouth,ma
no need to pull the timing cover.but you will need to remove the HPOP and HPOP gear to do this.you will need a few rags to fill the timing cover with to catch the metal shavings.
94f450sd
certified nutjob
plymouth,ma
worst thing that can happen is it dont work and i gotta yank the motor enough to remove the oil pan and swap covers.im willing to take this chance to get a cheaper and easier alternative to an accumulater tank.
look at the pictures i posted of my covers.you see the one with the tiny hole on the blue motor?thats the 95 cover.that tiny hole needs to be block cuz as you see on the dirty motor the 97 cover does not have that hole.now the hole you gotta drill for the stand pipe is gonna come in from the gasket surface into the cavity that has the tiny hole. hope you guys understand what im trying to explain.
Pm_guru
