thunk
Status
Not open for further replies.
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
Try greasing the grease fitting on the splined slip yoke on the rear drive shaft. Pump the grease in just until the rubber boot starts to swell.
no-red 6 0
Senioritis
southmetro MN
kent-
you referring to me????
i'll have to go look to see if i 'have' a zirk their...usually like to find them all and lube em up once in awhile...never saw one there..i could be blind too..
bush-
i may not have described it right...it is more of a 'slap' and it very well could be something w/ the shafts - i see that as plausible... you'd almost have to ride along w/ me for me to show it to you...what are u doing tomorrow....:lmao:lmao
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
kent-
I was aiming that as a reply to jageranimal. But it's applicable to anyone with a thunk coming to or pulling away from a stop.
doug young
Snohomish, Wa
thanks for all the replys and ideas boys. but as it turns out.......it is the lower ball joint on the passenger side.
thanks doug
jageranimal
san diego, ca
well i went to lube the driveshaft there is no zerk fitting nor a place for one, i used a smallinsulin needle to shoot oil in throught the rubber not change at all, i changed all my brakes which ended up being good and i ended up needing them and seemed to fix the problem but nope, i noticed it dosent do if if im turning while im leaving the light and dosenr do it the morning when its cold out im going to check ou tthe ball joints this weekend
thanks doug
well good for you & your diagnoses....its a DIY job (150 per side)...
or 900 PER SIDE if the dealer does it...
F350DRW1
Waylon Fan
N.J.
thanks doug
Your welcome. [see post #7 told ya it was ball joints:tounge]
F350DRW1
Waylon Fan
N.J.
but i said it FIRST in post #4 ! :tounge
You mentioned it, along with sway-bar bushings, as a rhetorical multiple choice answer. I found your answer to be very confusing, droll, and frankly no more informative than your rant about wiper blades. :stir
Status
Skram
