The Dreaded Chime
powerboatr said:
yes. low fuel, coolant, oil, water in fuel, door ajar (not a door), alt/battery, bascially any warning light will set off the chime, ebrake on to thats a good place to check for a switch not making full contact and driving down the road will let the pedal settle enough to light the light if the p-brake hasnt been kept adjusted. rare but it happens, dont ask me how i know:eek:
ALL of what Robert sez... Check >ALL< yer fluid levels, brakes, tranny. You might even try dis-connecting yer Batteries for about 30 minutes. (resets the PCM systems checks).
:dunno
Wood County Tx
SeventyMach1 said:
I have no lights & a chime. Now I'm worrying that I have a warning light bulb that is blown.
jey on will check al lbulbs,
plus if you turn the key on and press your mileage trip odometer to reset and hold it in then turn off your key and then turn it back on and release the trip reset it will place the ecm into a test pattern and do a full gauge sweep and light check, then you can scroll through about a half a million ecm checks and codes using the trip button. ,
it will reset when you cycle the key off.
this is providing you have the digital dash with green mileage numbers on the small lcd screen
xlt larait and up trucks
jguzman75
McAllen, Texas
Mission,Texas
I dont think this will work for the 2000 X. I tried last night and all i was able to quiet was the key in the ignition.
Djracer
Car Stereo Dude
Wetumpka, Alabama
on a bet one time I removed the cluster on a super duty and removed the buzzer itself. He said I couldn't get rid of it so I desoldered the buzzer and handed it to him!
f100cleveland
When In Doubt,THROTTLE ON
Southern Minnesota
When you guys figure out how to fix it post it cuz mine has been doing it for a couple of weeks now and I can't find the cause of it.
Djracer
Car Stereo Dude
Wetumpka, Alabama
I killed the key buzzer in mine yesterday thank goodness! I wanted to kill it saturday I was at a family reunion saturday listening to the truck stereo and had to close the doors! I had no internet access so I had to wait till I got home!
I'd just reach up behind the PDC in the cab and pull the chime module out...
kiarasue
The RamSmoker
Enumclaw, WA
chime
You know I just resently ran accross a how to for disabling them. I want the head lights to remind me but the key in is a pain when your trying to consentrate.
trickyricky23r
