Superchip in pmt3 computer code.
kman500hp
I have a 2001 ford powerstroke with a computer code of pmt3. The truck when stock would run between 18-20mpg. I was very impressed for the 7.3 mileage. I then added a superchip plug in module that used to be run in a pmt2 computer code. I sent the module back and had it flashed to run pmt3 b4 I installed it. I then installed it and under heavy acceleration I get a service engine soon light. Always when pulling a trailer I get a ses light. This never happened until I installed the chip. I also have a built trans. Does anyone have any idea of common failure or cause of this light? I may just remove it and put in a ts performance chip.
Wingdog
Thunder Bay, Ontario
Check your codes and see what comes up. I had my SES light come on whenever I pulled a trailer or was on the fuel hard this year ( never did it last year when I installed the superchips tune). Turns out my fuel pump was starting to go and could just not keep up with fuel demands. So check for over boost and under fuel.
TacoCat
