TexasExcursion
GOD Bless America!
I'm stumped. And frustrated.
After starting the truck up when the engine is cold--regardless of air temperature outside--it runs very rough, almost like it's running on 6 cylinders. No power, either. It does get worse when the temp's are colder, but even during the summer I'd have to let it idle for 10 minutes before driving it.
Here's what I've done over the past year to try and fix it:
-changed oil and filters (several times)
-changed fuel filters (several times)
-replaced EGR valve
-replaced turbo
-cleaned CAC and replaced CAC clamp
-flashed PCM with 06E17
-replaced K&N air intake with factory intake after Ford insisted the MAF on the K&N was giving the PCM faulty readings, hence the rough operation at start up
-disconnected EGR valve (worked okay for about a week, then truck started running goofy--surging--so I plugged it back in)
Is there anything else I can try? The problem is getting ridiculous and the clowns at every Ford dealership I've been to are completely clueless. Once it warms up it runs fine.
-is it the Amsoil 5W30 synthetic?
-is the motor shot?
Someone--please--throw me a bone here. Thanks.
-replaced EGR valve
-replaced turbo
-is the motor shot?
