Question Starting
IDSTROKER
Blackfoot ID
Blackfoot ID
I have a 2003 ford with the 7.3 it use to start with only 1 1/2 revoltions on the motor now it seems to take 4 5 or 6 revoltions i have checked the alt 14.6 volts and the batteries were replaced may of 2006 going to have checked the starter has 155000 miles on it never replaced. maybe wore out anything else cause this need some in put thanks.
If your batteries were replaced in 2006, you might need new ones. Over three years is questionable. If they are not tip top shape they will not spin the engine fast enough to start it right off. Starters usually drop dead rather than slowly die.
IDSTROKER
Blackfoot ID
Blackfoot ID
I have checked and cleaned all the cables the only one that looks bad is the starter end.
6.0PSD777
Mass
Not sure what u have for batteries now but if ur buying new ones i highly recommend Motorcraft. U will get an easy 5-7 years of life out of them and their not much more money - My .02
I'd say 3 to 6 revs to start is normal and okay, for a 7 years old 7.3 :dunno
Load Testing each battery might be worth it, for piece of mind, but as long as it cranks over strong.. and starts every time.. 3 to 6 turns ? yer Good To Go. No Worries
* On Edit ?
Seems I usta start.... on 1 cupa Coffee.. Nowadayz it takes 2, maybe 3. Time & Miles maybe ? .;):)
bigrigr
Real trks hv 3 pdls
provo, utah
Make sure the oils level is full, and check the fuel flilter as well. If the oil is low, it won't fire the injectors, and we all know what a partially plugged fuel filter will do. Always start with the cheapest and easiest first i always say. Good luck
Brad1103
